Pool filter leak at outlet
Galaxy
4
Az
Hello
I have Sta-Rite -Cartridge System 3 S8M150 filter.
After I cleaned up one month ago ,I noticed water dripping From outlet filter tank during pump on and stop when vacuum placed on suction side
When pump off ,I hear air leak noise
Tried to glue did not help (See attached photos)
Any help appreciate
thanks
Tom
Tom,, welcome to TFP! :wave: To make sure we understand ... is it leaking from the black fitting up against the filter itself, or the where the white pipe is connected? Also, what kind of glue to did you use?
it’s coming from black Pipe Inside where white Pipe goes ,no leak from outside pool filter tank and I used super glue
If I need to open black fitting any idea how to open that ?
thanks
Tom
So according to your Parts Diagram, the black parts are your filter's bulkhead retaining nut fittings. The pipe extends a bit then your white PVC threaded adapters (nuts) screw onto those. Super Glue probably wasn't the best choice, and hopefully it didn't prevent you from separating those items. If the dripping is bad, I'd be inclined to separate those connections, inspect the threads and any O-rings that may be inserted. If the O-rings sit flush on the face of the adapter nut, you shouldn't need any silicone, but if they are wrapped around they may. You may also want to try a few wraps of Teflon tape around each male fitting threads.
When vacuum running ,it’s does have only spot drip so I will leave it alone at this time
Thanks for your input
Tom
Reactions: Texas Splash
