Pool Filler Problem
ubiq
Apr 10, 2018
13
Riverside, CA
My garden hose pool filler contraption failed (again) and I'm trying to attach a less expensive float valve to the filler line. The pool filler PVC pipe is 1/2" and terminates flush with the pool wall. The 1/2" male threaded float valves have no way to attach to the pipe. I've tried turning down adapter fittings to fit inside the 1/2" feeder pipe and using marine epoxy to bond them together, but the water pressure blows them out. Is there a way to cut internal threads on PVC pipe? Another way to attach the float valve? Or am I stuck with replacing my Pool Sentry every 3 years?
Since it is below the water line, you may be able to install a true autofill.
Would required finding the pipe between the pool and water supply and installing the in-ground bucket with one pipe going between bucket and pool that will keep the water level the same and then the water supply connected to a true float valve in the bucket.
Not sure how to reliably connect a float valve to the inside of the 1/2" pipe in the pool. One option might be what you tried with the valve turned down and glued in the pipe, but also add a pressure reducer on the supply line so it would be less likely to be pushed out.
The autofill idea sounds interesting. Is this the kind of mod that a relatively handy do-it-yourselfer could manage? Are there kits? I suspect it would be easy to locate the line; the distance between the manual valve and the filler pipe aperture is minimal. Thanks again.
I think there are kits. It is just a bucket with 2-3 holes in it that you can attach pluming to. Should not be that hard.
Disclosure: when I had mine installed (needed a pipe drilled through the pool) I recall reading about how the pipe between the bucket and pool was supposed to be sloped a certain way or something to ensure that the water stayed equalized well or something. The line from the pool to bucket should be a straight shot and not have rises and valleys. So, I highly suggest you look for some of the kits and read the instructions and be sure that it will work with your current setup.
