Pool fill up
mmardini
174
Palm Springs, ca
This is the first time I’ve ever drained and refilled a pool. We started this morning at 9:30am and we have two hoses going. We are barely at the first step and it’s almost 6:00 pm here. My question is how long does it usually take a pool to fill? And how do you go about sleeping while it’s filling? I’m afraid I’ll
Wake up and it’ll be too full if we go to sleep. We do have an auto fill feature which is currently not on, but thinking of using that when the water gets high enough. Thank you for your help!
Then you do not want to stop until the water is at the tile line. Imperative. Set some alarms to check on it.
Only once the autofill entry into the pool is below the water level. You do not want water running down the side of the pool.
