Hi
New to the group and could do with some help. I have acquired a 20 x 40 in ground pool. It appears to be concrete with plaster walls. All of the equipment has been removed and piping cut back to ground level. I have established that there is 2 skimmers and one or two return lines to the bottom of the pool ( no returns on the pool walls) . The pool needs to be painted.so my first job is to Presure test the plumbing if all goes good Then go about prepping for painting. I have read up on this and I think I can get through it along with some mi or repair to the pool steps. I need some help in choosing the correct filter pump chlorination valves etc I a,so need to set up for a pool vacuum. As it happens that’s the only piece of equipment that was left and it looks in pretty good condition. I would appreciate any feed back on this. I haven’t filled in the pool specs on my profile yet as i don’t have anything to enter. This is a great group / forum. I have read and learned so much so far
Thanks so much
Brian
Thanks so much
Brian
