I'm hoping to get some feedback from anyone that has converted their concrete deck to pavers. I was given a quote for remodeling my deck with pavers. It was described that the pavers would go on top of my existing deck (effectively raising it about an inch - 1.5 inches) Part of the project would also entail them adding a much bigger 3" drain as well (currently I have a little baby maybe 1" drain).
Now since Irma something seems to have collapsed and I've been receiving huge amounts of water from my neighbors yards both of which as higher than mine. I'm building a trough against my fence that should reduce the water flow but raising my patio an " and increasing the drain should also keep a lot of the water from going on it in the 1st place.
I was wondering if that seems like a sound plan? If anyone has any experience with remodeling concrete to pavers. Are they durable, can water seep underneath (between concrete and paver) Anything else I should be aware of with pavers vs painted concrete....
The whole job (pavers, drain, refinish pool, and add new tile to the pool) has been quoted @ $13,000 so far from a very reputable company (blue horizons). I will be taking other quotes as well and hoping to do all the work next spring. Any ideas appreciated.
To note my pool deck is already surrounded with rocks (not dirt) with frech drains embedded under them. The water and diret are coming from my neighbors house on the right where I'm building the trough to keep it out. I have a similar trough in my backyard and it seems to stop almost all the water from that neighbor from getting in my yard (or slows it down enough so I don't see it).
Here's a close up of the river of water coming under my neighbors fence, and you can see the trough in the back not allowing anything through... If given enough time water will make it's way to my front yard and public drainage. Just whatever happened after Irma seems to have overwhelmed my drainage for now...
