Is it possible for a sump pump to be too strong for my pool cover causing it to suck pool water through the cover and out? I use a tarp style cover for my inground pool and the pump i used last year died so i tried using a sump pump i already had that was 1/3 HP- 9.0 AMPS. After a while i noticed the level of dirty water on top wasn't going down and the pool water level was lowering significantly. I just bought a new tarp to close last season and i don't see any holes (which is what happened last time) so i'm wondering if the stronger pump could be the issue.
Thank you
Thank you
