Pool Coping for Steel wall vinyl liner pool
Barnon
0
13
Central, TX
]I will be installing the coping soon on my DIY pool. I will have a concrete deck butting up to 3.5 wide x 2.24 high x 9 inch long bull nose coping with an expansion joint in between. I'm in the process of pouring a concrete base about 12 inches wide x 6 inches deep reinforced with rebar that bridges across the deck supports because I don't trust my back-fill. I was planning on bridging across the back-fill with the concrete deck which would tie the coping base to the concrete deck. Option 2 shows the coping base and the deck with the rebar separated as to let the deck float from the coping base. Some pics are included below of the build. I was planning on using a modified thinset for adhering the coping around pool walls. I'm wondering what I should on the stairs since most of the coping blocks would be sitting on the plastic but need to be space up about 3/8 of an inch to match the height of the other blocks. Any advice would be greatly appreciated.
Beautiful pool.
While I cant really help with your questions, I'm curious why you have all those links in your post? One of them (x 6 inches deep) re-directs to Overstock dot com for furniture, and it's not even pool related.
Not sure about the links... I'm not seeing them now but I kinda remember some of my words being highlighted when I created the post. I did copy most of this from a post I first created on diychatroom. Sorry for that, It was un-intentional.
