So...I am getting frustrated.
Have been following TFP the last 2-3 years, and have learned a lot from this. But I am stumped at the moment.
I opened my pool 4 weeks ago. After opening and to be safe, I SLAM the pool. After 1 day...no CC and passed OCLT. Water was also clear.
Fast forward to 4 weeks later. Because of the cooler weather, we have only swam in the poo 5-6 times. Short swims only. And maybe had 6-8 kids once or twice. I have been testing 2-3 days and feel that my levels have been the best they could be. PH was always in the 7.6-7.8 range...TA started low when opening and bumped to 70 and have been steady since. CYA was low and bumped to 60-70 and have also stayed steady. Same with CH...steady.
FC fluctuates from 4.5 to 11...but if I average them out, it is in the 8.0 range. Pump runs 24/7 with higher RPM overnight, and lower RPM during the day. I also use a skimmer sock. I have only vacuumed using a robot (walls and floors) and havent vacummed manually at all this year.
Here lies the problem...last week after a 2 hour swim, pool was slightly cloudy. 2 days ago...same result, slightly cloudy after the swim. When I say slightly cloudy...I am sure other's will not notice...but since I am particular about the water clarity, I find it cloudy.
I did the OCLT just to check and sure enough I failed, as I expected. What gives? How do I go from passing to failing in 4 weeks after not swimming too much at all. It has also been cool in the last few weeks.
Any thoughts or idea?
