I need to close my pool by Friday night; we ask friends to help get the cover on and I need to ask them in advance.
I am confused (about a SLAM) as I read through many posts.
Here's my situation, I'd like some advice.
This summer the chlorine numbers have stayed stable. The time I did a one-night SLAM, it held the OCLT but it took several days to get the chlorine down.
Here are my questions:
1. Do I need to do a SLAM before closing? Or can I bring it up to FC: 5 and put on the cover the next day?
2. What should the CL be when I put on the cover (woven solid cover, with water bags)? My real concern is weakening/damaging the cover (happened in the past) when the CL is too high.
3. I usually use Polyquat60. I read that the CL should not be high when it is added. What is too high?
Thank you!
Test data tonight:
FC: 2.0
CC: 0
ph: 7.5
TA: 95
CA: 9 (vinyl)
CYA: 35
IG 20K vinyl liner, use liquid chlorine
Thank you!
Test data tonight:
FC: 2.0
CC: 0
ph: 7.5
TA: 95
CA: 9 (vinyl)
CYA: 35
