A lot of questions here. Pool build is in process. 16x32 vinyl liner pool with 7x12 sun deck. Pool builder started in September and we got 10 inches of rain throughout the month so he won’t be able to finish pool until spring. He got as far as pool walls up lines set up and concrete deck completed. Inside the pool is still dirt/mud. He is waiting to do the concrete mix and install liner in the spring.
Is this okay to leave like this over the winter?
equipment has not be installed yet and he is waiting for spring to finish the equipment pad.
When we talked about location of equipment pad I wanted it located out of view from the pool and about 30 feet from the pool. He didn’t recommend this because he said it would be very expensive to close pool each winter because of the amount of antifreeze we would need to fill the pool lines.
Reading these posts it seems like he closes pools differently. I asked him about blowing out the lines and he said he doesn’t recommend it and just fills the lines full of antifreeze including pump/filter and heater. Is this correct? He has been building pools for 40 years is this something that used to be necessary and is no longer a recommendation?
