- Jun 24, 2021
- 16,783
- Vinyl
- CircuPool RJ-60 Plus
No. Your Navien will stay your Navien and heat your house water. The pool water will be heated by a stand alone heater connected to your pool water circuit. You pool heater works by itself...Ok maybe I'm confused. I am getting a separate gas heater for the pool. But I thought my Navien combi/boiler unit in my house had to be rated with enough btu's to now also supply my pool heater, correct?
Your gas meter needs to be sized for the total property load.But I thought my Navien combi/boiler unit in my house had to be rated with enough btu's to now also supply my pool heater, correct?
You will need a sufficiently sized gas connection to your new pool heater.
Yes but I was thinking since I'm running a gas line from my navien to the pool heater the size, btu's etc. of my navien matters. No?No. Your Navien will stay your Navien and heat your house water. The pool water will be heated by a stand alone heater connected to your pool water circuit. You pool heater works by itself...
Got it, thank you very much and will do.Your gas meter needs to be sized for the total property load.
Show the gas meter and describe all gas appliances with their associated BTU/hr rating.
If the gas line to the boiler is big enough, you can do that, but it is unlikely to be big enough.it would be SOOO much easier to run gas line from boiler location to backyard.
"Pool" guys rarely know about installing gas lines and gas appliances.Why wouldn't any of these pool guys even ask what I'm using for a combi unit/boiler etc. in my house
