And then, the electrician. The electrical work was great! Gave us an extra outlet by the house, upgraded the garage subpanel to 50 amps, put a switch on the outside of the garage for the light by the pool...
But absolutely no idea of how to bond a resin pool. Or any pool, really. Or what a water bond was. And an attitude that as the pool builder I should have told him how this fancy new all-resin pool was supposed to be bonded. If you really are curious, here's a thread:
Hi all, Is what we have here safe? My question is about how much of the bonding wire needs to be in contact with the ground, and also why it needs to go all the way around the pool. As the pictures show, the wire is only touching ground where I have dirt piled up. The wire does travel about...
www.troublefreepool.com
If you're not, highlights are that they screwed the bonding wire to every resin upright, 6" above grade. Which is very not correct. And then they argued with me over and over again. I finally just did it myself. Still waiting on them to send the final part of the bill to let them know I won't be paying fully.
