Can anyone identify this pool bubbler? My Google searches have turned up everything but one that resembles this. Trying to figure it out so that I can find a removal tool for it. I don't have a particular need for it at the moment, but I don't want to need it and not have it.
Believe it just screws in. Should be able to use a screwdriver in one of the slots and tapping lightly on it to unscrew it. Righty tighty, lefty loosey
Yeah, I am certain it is threaded in. And 10 years ago, I would have done just as you suggested, using a screwdriver. However, as I have gotten older and broken or damaged more stuff by utilizing a 'good enough' tool, I have come to appreciate having the correct tool. If I can't figure it out, I'll make a tool to fit those three tabs.
A&A Bubble Jet Fountain (Complete) - Gray - 564025 - for shallow areas, adjustable for depths from 4 to 8 inches, retracts flush with pool floor, no maintenance
sunplay.com
Haven't found the removal tool, but believe they use the same as the A&A Style 2 tool. I found one on Amazon and will advise.
Just to close this one, for anyone else searching...
These are the A&A Bubble Jet as confirmed above, and use the A&A style 2 tool for removal (A&A Manufacturing Style II Installation Tool # 522079). They take a 1/4 turn to remove/seat and slide out. See photos below.
