I recently bought a Pool Blaster Max CG and I am having a hard time putting the Blaster unit on to my Leslies Pro pole. Is anyone else having the same issue? You really have to jam it in and it is a real pain to take it off my pole. My pole fits all my attachments very easy and smoothly even non Leslies products. My pool pole is the standard 1 1/4 size. I am going to go to the Leslies store tomorrow to try it on other poles to see if it is my poll or the Pool Blaster unit causing the problem. One other note, the Pool Blaster Max CG does a really good job at vacuuming my spa and my Baja area of my pool. My Pentair robot does not clean those areas and the Pool Blaster is a perfect tool to clean the bottom area and steps. It saves a ton of time vs getting the vacuum hose and the bottom cleaning unit out to do the job.
