- Apr 10, 2018
- 6,327
- Plaster
- CircuPool RJ-45 Plus
Do you have a variable speed pump? The salt cell that you have is designed to be installed as the highest component of the plumbing system. This means that all air and gases accumulate at the top of this cell. Having had this same style, I found that my cell was filling up with air when running at low speeds and the plates were becoming exposed. Likely, the system was also shutting down due to lack of flow when running at low speeds. If you have a single speed pump with sufficient flow, you likely will not an air bubble at the top of the cell. Just mentioning this as a possible factor to the inconsistent generation of chlorine.
