Second year inground pool owner here, first year closing myself.
Can I get a confirmation if this very brief step by step for adding antifreeze is accurate??
-Drop water below skimmer inlet
-Blow out lines
-Remove eyeball jets, insert caps/close off
-Add antifreeze to skimmer until full (??)
I guess my questions is 'Do I just only add antifreeze from the skimmer to the pump/filter (disconnected), or do I also add it from the pump/filter to the outlet jets that are now closed off??
Just a clarification, you need to blow out the return lines. Not clear from your description that you are doing that. Mine are still below water level if i drain just below skimmer opening. Are you capping the jet openings WHILE blowing out the lines?
