Just purchased a house in Arkansas with a pool that hasn't been used in two years. The cover was partially in the pool and the water is green with leaves and frogs in it.. So far I have removed the cover, using the net got most of the leave I could find, added a box of shock that was in the garage of the house and put in 6 cups of powder chlorine. I got the pump ( sand) running and have the water level to the middle of the skimmers and everything seems to be running correctly. I have a test kit that was at the house and checked to red side (ph) and it seems to read about 7 and the chlorine ( yellow ) seems to be 0 or very close.. I am not sure how to determine the # on this little kit... The pump has been running for the last 3 days and the water looks a little clearer but not as clear as I think it should be by now.. The pool is square and pretty big, liner pool and seems to be about 25 ft by 50ft with the deep part in the middle and shallow on each end...
Now, that is all I know about that.......
Where do we start.. Pump running, water moving, 1 box of shock in and 6 cups of chlorine in today.......
Help.....
Help.....
