For the past two years I have closed at 1/2 SLAM level and added 16 oz. of Polyquat 60. Everything looks good upon spring opening. I have seen some threads where it is believed that the Polyquat is unnecessary. Just close at SLAM. So, do I need the Polyquat? It, like everything else, has gotten pretty expensive.
It gets pretty cold here in the winter, with the pool usually frozen solid for the first 3-4 inches on top, from mid-to-late December until late March/early April. I lower the water to about 3" below the skimmer and the return, and close as soon as the water temp hits 60 degrees usually mid-October. I use a screw-in plug on the return and pool noodles in the skimmer. I also use a solid cover with a pillow. I remove any fallen leaves from the cover around November 1st. Then, aside from shoveling excessive snow off the top as needed, I forget about it until spring. By plugging the return and "noodling" the skimmer, along with spring rains, I usually open to a pretty full pool. This eliminates putting excessive strain on our well.
