I have a small leak in my Polaris pump. Initially, I though it was the drain plug. After lubing the O ring, I reinserted the plug but it still has a leak. Its 20 year old system and never had any problems with except for changing out the cleaner from 290 to P39. I am thinking I need to replace seals, O rings, and anything else that may be broken. So my plan is to dismantle the pump and look at all the parts. From other posts, I read that the parts are hard to come by. My questions;
1. While I take time doing this, is there an easy way to bypass the motor/plump plumbing?
2. Do you normally take out the assembly and work in the garage?
3. Any other suggestions or comments? Thanks.
