Hi all ! I'm new to the forum, and also a newbie pool owner (about 2 years). I haven't run into major issues so far, so I'm still learning
Here's my issue, if anyone can't help me troubleshoot it, that would be great because I'm getting frustrated.
I had to replace the back-up valve of my Polaris 360. I ordered a new one (case + mechanism) online. I replaced the old one, it was working well for a few days and then the valve started to get "stuck" in reverse mode. I contacted the shop where I bought it and they replaced the mechanism part. Again, it was working fine a few days, and then same symptoms ! I noticed a lot of water coming out from the pressure relief valve (at the quick disconnect) so I changed that piece (the pressure relief valve only). Polaris going strong, back up valve cycling correctly. Until yesterday. I come back home, stuck in reverse again. This time I noticed a tear in the hose (wasn't there before). So I shorten the hose a little bit to remove the damaged part. Everything works fine for a few cycles and then it gets stuck in reverse again ! I don't know what else to check... The RPM looks good (30 RPM as I checked yesterday). Back up valve mechanism seems ok when I open it, it doesn't get stuck, no debris etc.
I also removed the cleaner at some point (only left the back up valve and whites hoses) and it didn't help - so I'm thinking the problem comes from something "before" the back up valve.
Any advice on what to do or check next ?
Thanks !
Caroline
Thanks !
Caroline
