Is there a way to reuse the jandy valve on the left if I plumb into that section with a swg?. It looks to me like I will need to cut it out on the vertical pipes since the run between the filter and the valve has a bunch of jogs and no place to plumb in the swg. The swg would go into a new section that leaves the filter and goes back then up and then front to drop back down to jandy valve.
