I'm installing a HP50ha heat pump. According to the install manual a bypass valve is "optional" it doesn't make clear if I still need to tee Togeher the supply and return after the isolation valves . Can I pipe in, pipe out with no ill effects?
https://www.hayward-pool.com/pdf/manuals/HP50A-HP50HA-Manual-English.pdf
