Thank you very much!I would recommend posting a couple more pics of the area, but further back so we can see everything and the plumbing on the pad. Unfortunately, that fitting will need to be replaced. It appears to be on the pressure side exiting the filter just before that T-fitting with the spigot. That fitting also appears to be glued into that T-fitting, so a little re-plumbing may be required to get it all back to original. Not really difficult, just requires a bit of planning for the right fittings, etc. More pics might help with advice though.
Thank you so much!I just realized something. On that Jandy filter adapter you have two pieces. You have the one side screwed into the filter housing (bulkhead fitting), then the other end (the broken half union nut) connected to the T-fitting. They sell replacement bulkhead and half union nut connections as noted in the link below. The trick is to connect a new half union nut the T-fitting since the old one is glued in. Sometimes you can find a slip-on (glue) adapter to accommodate odd scenarios, but in other times it's just as easy to cut it out and start over as I explained above. Others may have other thoughts though.
Jandy CV Series Cartridge Filter Parts Models CV340, CV460, CV580
PoolZoom Pool Parts and Pool Supplies Online. Huge In-Stock Inventory, Quick Shippingwww.poolzoom.com
Thank you Jim and thanks all - very much appreciated!Craig,
The right way to fix it is to replace the union.
That said, I have a rent house pool that uses similar unions on a salt cell. It was broken just like yours. I epoxied the crack as a temporary fix and ordered the replacement unions. That was about 3 years ago, and I still have the new unions in a box...
Obviously, you have to make sure you just epoxy the crack and don't epoxy the union to the pipe.
Something to try anyway..
Jim R.
Thank you!I would probably just plan to replace the whole section between the pump and the filter... You will need the sweep and the two 1/2 Unions (I think the pump side is probably the same part as the filter side, but you will want to check that.) You'll also either need a new T if you want to keep the faucet in it's current location, or the faucet can be plumbed into the plugged port on that style of sweep.
I think that Craig's sweep is the original Jandy part:Would be a great time to get rid of that ABS DWV sweep as well.
You may be right. It has deeper sockets than DWV. That short run from pump to filter has no leeway on cutting the fittings to the right size. Adding in a loop might allow a little wiggle room for lining up both ends of the fittings, especially if that’s why the one side cracked. Don’t know for sure, but I could mess that one up 3 times before getting it just right…I think that Craig's sweep is the original Jandy part:
It certainly looks identical to my own installation (and the sweep on my pump has "Jandy" and the part number)
In any case I'd recommend using the Jandy part when rebuilding it.
Thanks again to everyone for all the assistance!You may be right. It has deeper sockets than DWV. That short run from pump to filter has no leeway on cutting the fittings to the right size. Adding in a loop might allow a little wiggle room for lining up both ends of the fittings, especially if that’s why the one side cracked. Don’t know for sure, but I could mess that one up 3 times before getting it just right…
