Backfill comes tomorrow afternoon so this is my last chance at changing anything. I guess I'm making sure that I'm not overlooking anything big here.
There are 3 returns all tied together and one run back to the pad. It's all 2" flex pipe. There will also be 4 deck jets installed on this loop. So I'll be able to turn off the returns to increase flow to the deck jets.
There are 2 skimmers (suction) that are both 2" home runs back to the pad. Give me control over shutting one off for vacuuming. This loop contains the slide as well.
No main drain. No return to waste. No vacuum port.
There is a 2nd loop with 2 suction valves tied together that run back to the pad in a 2" pipe. There are 2 returns back to the pool - a waterfall and deck jets. I think these are 1 1/2" pipes.
I assume flex pipe is OK because I'm in a freeze / thaw climate and do not have termite issues. We do have rocks though.
