Hi y'all
I'm wrapping up pool design and trying to go for a functional single-pump plumbing layout. (Going to bid next week)
I would appreciate any commentary, suggestions, etc.!
Thank you in advance.
Pool: (Single Body) 82.5K gallons / Spa 1.5K
Pump: Pentair Intelliflo XF
Filter: Pentair Quad DE 100
Heater: Pentair 400K BTU Master Temp NG Cupro-Nickel
Controller: Pentair i9+3
Water Features: (2) 36" Sheer Descents on Back Wall & (2) Pressure Ports for aerial cooler sprays
Drains: (1 spa, 1 pool) Paramount Superflo 360
Leaf Collection: (1 spa, 1 pool) Paramount Deck Debris Canister with MV-Fuse SVRS
Skimmers: (4) Paramount Paraskim V Venturi
Auto-fill: Paramount Paralevel
Basic set-up:
Drains:
Pool Drain + 4 skimmer lines | Spa Drain
Returns:
Sheer Descent Return | Pressure Port Returns
Spa Return
Wall (Chemical) return
Floor (Heat) return
Guesstimate on Pipe schedule:
Drains:
1: 3” pipe from Pool drain
4: 2” pipes from 4 Skimmers
1: 3” pipe from Spa drain
Returns
1: 3” pipe to Spa Loop
3: 2” Pipes to 6 Pool Returns
3: 2” Pipes to 8 Floor Returns
4: 1.5” Pipes to 4 Venturi Returns
1: 2” Pipe to Sheer Descents
2: 2” Pipes to Pressure Ports
Other Pipes
1: 2” Pipe run to Spa Air Loop
1: 1.5” Water Level equalizer pipe @ Spa to pool
1: ¾” Pipe run to auto-filler
1: ¾” Pipe sump pump run from Convo Pit to grass
1: 2” Yellow Natural Gas Pipe to Heater
6” Street Drain Line
4: 2” Overflow Pipes from Venturi Skimmers
8: Deck / Area Drains
1: 2” Pipe from Multi-Port Valve for waste drain
Basic set-up:
Drains:
Returns:
Spa Return
Floor (Heat) return
Drains:
Returns
Other Pipes
