New build on-going and new member.. So glad I ran across TFP when doing research. Routinely the best info! Amazed at how much money is being spent by pool owners on pools based on “rule of thumb” or “that should work mentality”.
Reaching out for review of our plumbing and hydraulic calc’s.
Attached is a diagram of the piping layout. Not pictured is optional home runs for the water features (3 bubblers in the tanning ledge) and home runs for 6 deck jets. The diagram has the bubblers being supplied by a symmetrical loop and 6 deck jets are supplied with a serial loop.
Considering Pentair eqpt and automation—two variable speed pumps, quad de filter, uv sanitizer, automation, heater (perhaps Hydra Royal 137,000 btu).
Smmary of the system.
Suction Side:
Concerns at this point:
Suction Side:
- 2" Discharge 32" Trench Drain
- All three ports available for return / suction
- Actuator valve to split return load to top and bottom returns (advice pls)
- 2 Quikskim Venturi Skimmers
- Multiline or home runs to each
- Top return Loop: 4 returns supplied with a serial loop
- Would like to run the V-Fitting Venturi Control
- Actuator Valve
- close / open top return loop to concentrate heated water to bottom return loop
- perhaps to increase velocity of return to bottom for periodic cleaning
- Bottom return loop: 4 returns supplied with a serial loop
- Actuator Valve
- perhaps to increase velocity of return to top for periodic cleaning
- Actuator Valve to control flow to skimmers during cleaning (Advice pls)
- Water Features
- 3 bubblers with symmetrical loop
- Will we need independent adjusting valves (manual)?
- Actuator Valve
- 6 deck jets
- Alternative piping depending on desired head loss and velocity
- Serial Loop
- Will have individual adjusting valves
- Home Runs
- Home Runs with 1" pipe (vs. 2" serial loop configuration) doubles the head loss and velocity
- Serial Loop
- Actuator Valve
- overall pool volume: 32,427 gallons
- 8 hour turnover requires 67.6 gpm
- system head loss 50.58 ft hd loss
- water feature head loss 64.7 ft hd loss
- Can a system have too low velocity to function properly?
- Both return and supply is under 3 ft /sec.
- Do I have enough suction capacity to run both system pump and water feature pump?
- I have duplicated the suction capacity on both the water features and the system pump head loss calcs to have a suction component to figure total system head loss each.
- Are pipe sizes too large?
- Compared to most that I am learning, most pool piping is around the 2” size. As you see on the calc’s pdf, I am using 3” suction piping, and 2.5” for the top and bottom returns and for the water features (subject to a switch to multi line or home runs).
- How does one “right size” pipe to meet the needs of the bubblers and deck jets?
- I have read one needs approx.. 10 gallons per minute at 1’ head loss (for bubble itself) for the bubblers. I have 2.5” home run and symmetrical loop with 1.5” line to the bubbler. I have seen recommendations that 1.5” will service all three.
- I have been recommended 10-15 gpm for each deck jet. As mentioned above, questioning a 1” home run to 6 jets or use a 2.5” serial loop.
- Do we need valves to adjust flow for the bubblers if we have the 2.5” (or recommended size)?
- Should we have this engineered before proceeding with the plumbing? Any recommendations of who could review?
- Any feedback on the calc’s?
