I'm installing this pool below this spring. I will have 3 main return lines all three on separate runs from the pool equipment pad, and wanted to add an extra 4 inlets on the tanning ledge just to help blow debris off the ledge. My plan for the 4 tanning ledge returns was to run 2 extra lines and split them in the middle so each run as 2 inlets. Is this an issue?
