PLEASE help with replacement parts
bcw0530
2
Pennsylvania
Hi! We purchased a used pool last fall. We tore it down ourselves and discovered the bottom rail was corroded. We figured, okay, we’ll look into replacement parts once we’re ready to install in the spring (now). The issue is I can’t seem to find replacement parts. I believe the pool brand is Outer Back (I have attached pictures). The previous owner indicated the pool is about 10-12 years old if that helps. Thanks in advance for your help :)
Hi,
Welcome to TFP. Can you please fill in your account details and maybe list your equipment in your signature. It will make it easier to identify your equipment.
The Outback pool is a model offered by Barrier Reef Fiberglass Pools LLC. Models: Outback Dundee and Outback Escape
There is also a line of pools referred to as outback by a line of above-ground pools offered by Royal Swimming Pools. Model: Legacy Outback
This might help you also tracking down the correct part(s)
The image shows the logo for "OutBack Above Ground Pools". OutBack pools are known for their durability and all-weather protection. They come in various shapes and sizes to fit different yards and budgets. The steel components of OutBack pools are treated for corrosion and UV resistance. The company, formerly known as Cornelius Pools, has been manufacturing pools for nearly 50 years. Pools Out Back specializes in custom pools and has been serving the Texas Panhandle for over 40 years.
