Please help troubleshoot Purex triton minimax plus
1slowcrx
Active member
Mar 25, 2019
41
pomona, ca
Hi everyone, i have a older minimax plus that was working great. I went to try and turn it on yesterday and the service light is on along with just the power light. pilot is not doing anything. but when i turn the temperature down the service light goes away but still no pressure or heat light comes on or any spark from pilot. i tried jumping the pressure switch/wires and still nothing. I would greatly appreciate any suggestion on what i can try and check thank you.
The lights on the left of the controller go through the loop.
-tstat
-aux
-pressure
-heat
If the power light is the only thing on, most likely the thermostat is bad. Jump the tstat to confirm(test only). It’s the most common part replaced in those heaters.
this is the front and back. if I turn the pool temperature down the service light turns off but that's it, nothing else happens.
