Hi everyone, I am a new pool owner and am feeling so frustrated and overwhelmed. I have a summerwaves 16" pool and initially installed it directly on my lawn but quickly realized it was not level. Thankfully we only got a few inches of water in.
We decided to completely pull out the grass and then we layered sand on top to level. I only realized afterwards the manual says not to place on sand. Anyways...my pool is now full and it's about 2 inches off on opposite sides. Also about 4 of the posts on the left middle side (not on the low or high side) are sitting fairly close to the edge of the sand. I've also noticed that the posts on the high side are pulling a little towards the high side. Should I be worried? I'm kind of freaking out right now because I live so close to my neighbor (literally 10 feet away) and I am afraid that the whole pool will fall and all the water will go into his house! We laid the blue tarp on top of the sand before we put the pool on top - don't know if that will make a difference on its stability. A friend told me the sand will settle and get hard which will make it more stable.
I've read suggestions to do one or more of the following:
1) drain 1/2 the water and only put pavers under the low side
2) put pavers under the posts that are at the edge of the sand and then pack the pavers/posts with dirt.
3) leave as is and lay bricks around the posts and pack the gap with dirt
Are any/all of these suggestions a good idea or should I start over and use dirt instead of sand? I've invested way more than I anticipated considering I was really only planning to get 1 year out of this pool.
Please note, I've had the pool up and filled for only 18 hours.
