Hi Everyone!!
We've met with 2 PBs so far that seem to be somewhat near each other but we would really love more eyes on these bids. They seem high to us but our only real comparison was my parent's pool that was built in 2009 in Austin...so not a great one. Haha. We are building in Houston, TX and just want to make sure that these seem reasonable or high or what. And if there is anything else we should be asking about or was left off? Seriously, ANY help is appreciated! Any of the pool experts we know are out there - please share your knowledge!
PB 1:
GENERAL SPECS
Pool Perimeter:74
Square Feet: 288
Pool Length: 23'6"
Pool Width: 13'5"
Pool Depth: 3.5' x 4.5'
Steel: 8" On Center
PLUMBING
Skimmers: 2
Returns: 4
Main Drains: 2 *if booster pump added, will be more suctions
Gas Run: 130
GUNITE AND INTERIOR FEATURES
Steps into pool: Yes-3
Bench(es): 1
Tanning Ledge:1
Raised Pool Wall
12" Raise (LF): 33
Columns
18" x 18" x 18": 2
POOL PLASTER White Marcite with LunaQuartz Plaster Grade
TILE AND COPING
Waterline tile: 6" standard
Coping: Travertine
ELECTRICAL (up to 100' inc.)
Over 100': 5
Sub Panel: Yes
*DECKING *400 SF Min, could show 400 but be less
Deck Type 1: Spraydeck Square Feet: 400
Deck Drains (LF): 145
SPA Yes
Spa Light: 100 Watt
Blower: 1.5HP
Spillway: Standard
Jets: 6
Raised: 12 Inches
WATER FEATURES
2' Scuppers: 3
POOL EQUIPMENT
Pool Pump: TriStar Var. Speed
Pool Filter: 525 Cartridge
Pool Light(s): 500 Watt
Quantity Lights: 1
Purification: Chlorinator with Del Ozone Eclipse System
Auto Cleaner: Navigator
Pool Controller: E-Command
Pool/Spa Heater: 400K BTU
Prices don't include underground reroutes, sod, sprinklers, landscaping, furniture unless written. Total: $52,500
PB 2:
PB 1:
GENERAL SPECS
Pool Perimeter:74
Square Feet: 288
Pool Length: 23'6"
Pool Width: 13'5"
Steel: 8" On Center
PLUMBING
Skimmers: 2
Returns: 4
Gas Run: 130
Bench(es): 1
Tanning Ledge:1
Raised Pool Wall
12" Raise (LF): 33
Columns
18" x 18" x 18": 2
TILE AND COPING
Coping: Travertine
Over 100': 5
Sub Panel: Yes
SPA Yes
Spa Light: 100 Watt
Blower: 1.5HP
Spillway: Standard
Jets: 6
Raised: 12 Inches
WATER FEATURES
2' Scuppers: 3
POOL EQUIPMENT
Quantity Lights: 1
PB 2:
Pool Structure: | Beam to be a 12" box | |||||
Pool walls minimum 6" | ||||||
Pool floors minimum 6" | ||||||
Coves minimum 8" | ||||||
Deck dowels to connect pool to decking | ||||||
Equipment Specifications:_____________________________________________ | ||||||
Pool Filter | 430 Cartridge with Spa | |||||
Filter Pump | 2.7 HP VS Pump | |||||
Feature Pump | 1½ HP | |||||
Pool Cleaner | Polaris 280 | |||||
Sanitizer(s) | Rainbow 320 Chlorinator and Ozone Joe Ozonator | |||||
Heater | Hayward 400.000 BTU Heater | |||||
Pool Lights | 1 | Hayward LED Pool Light(s) | ||||
Air Blower | N/A | |||||
Warranties___________________________________________________________ | ||||||
Equipment | 3 Year Warranty on Equipment | |||||
Gunite Warranty | Lifetime Structural Warranty | |||||
Craftmanship Warranty | 1 Year Warranty on all pool workmanship | |||||
Mechanical Specifications:_____________________________________________ | ||||||
Skimmers | 2 | Hayward | ||||
Pool Returns | 3 | 1.5" Schedule 40 PVC | ||||
Pool Main Drains | 2 | Anti Entrapment, VGB Compliant | ||||
Spa Main Drains | 2 | Anti Entrapment, VGB Compliant | ||||
Pool, Lights and Equipment to be wired persuant to current NEC code. | ||||||
Sub Panel Included | No | |||||
Pool Coping, Decking and Drainage:__________________________________ | ||||||
Coping Material | Natural Stone Travertine | |||||
Waterline Tile | Standard Ceramic | |||||
Deck Size/ Material | 468 | Sq.Ft. of | Stamped Concrete (400 sq.ft.min) | |||
4" Drainage | 0 | LF | ||||
Deck-O-Drain | 0 | LF | ||||
Overflow Line | Yes | |||||
Fill Line | Auto | |||||
Pool Interior___________________________________________________________ | ||||||
Swimming Pool Interior: | Redman White Mini Pebble | |||||
Pool Controller_______________________________________________________ | ||||||
Automation: | PDA Prologic PS-8 - Pool Spa | |||||
Additional Items____________________________________________________ | ||||||
Raised Beams | | |||||
Pool Entry: | Tanning Ledge Per plan | with three bubblers | ||||
Benches: | 1 | |||||
Water feature | ||||||
Total Project Cost_____________________________________________________ | ||||||
Total Retail Price of the Project | ||||||
$57,780 |
