Please Help Me!!
Test 6 at 730ET was FC of 10. I added 27oz. First time I have added since 145PM. I plan on checking it again around 10 for the last time tonight then back at it in the morning!!! I hope all is still going well for my SLAM! While I am a bit more relaxed, water still looks horrible and I know I still have a long ride.
Yep, your SLAM is in process. Ok BRM, will check back and catch up in the morning. Relax now, SLAM is in town!
Don’t worry, you will soon see improvement!
Last test of the night. FC is 13.5... So from 1:45 til 10:15, I only had to add chlorine 1 time and it was to get up from a FC of 10 at my 7:30 test. We will see what happens in the morning! Look for me to post bright and early!
Good morning. Small adjustments is about all you should ever need the rest of your trouble free pool life.
You like many of us that close, will make the big adjustments to get the ball rolling but after that it is a tweek here and a tweek there and it keeps us in the Happy Place.
I love the confidence already in your posts, I assume you feel it welling inside too. #Proud of you
Rain? You will laugh at rain. Your pool can handle just about anything right now.
The days of ok’ish in the am and cloudy disaster in the pm will be a fading memory by the end of this season.
Keep checking and updating, but it is all babysitting from here.
Well it all comes down to what is practical for you but the more you stay on top of it, the quicker it tends to go.
Yes you've got to keep at it until the pool is clear and yep you should also be running the filter 24/7. Don't forget to monitor the filter pressure and clean/backwash when it rises 20-25% from the clean pressure.
Hi, Brett, first time checking on you today... I’ve been running errands all day! How is your water looking?
Jeff is right! You know what they say... took time to get this way, and will take time to fix!
Yep Patience is all it is now. The filter is doing it's thing and it will take the filter longer to clear the scene then it did the Chlorine to make it. Sounds perfect that you are not adding a lot of Chlorine. I am not either, very minimal amounts.. but I too am waiting on my filter.. small changes it seems because there is a lot to accomplish, however it will get better and once it is clear, you will have trouble remembering these days of waiting, oh and it will be worth it.
Cheers
