My sand filter needs replacing because there is a leak. The leak is in the very bottom, somewhere under the housing that it rests on, that housing came with the filter when it was new back in 2010, so I got about eight years out of it. Is that normal? Doesn't matter I suppose?
The water loss is probably 1/8-1/4 inch per day, but that may be increasing over the past few days because that is what I suspect.
I am going to have a plumber install the sand filter.
1- Could you guys please recommend what filter you feel would be best in my situation.
2- how should I handle the pump runs times?
I am very used to testing and treating the pool without the pump running over the winter about monthly, then again in the fall and spring because I open late each spring and close early each fall because I use a solid cover which requires me to test and treat and circulate the water on a weekly basis without the pump running because the pool is closed during those 3-4 months yet the water temperature is above 60°F.
I can just let the water kind of gush out of the filter leak and add 0.25+ inches of water per day; but I think what would be smarter is to simply test and treat it daily just like I do during a winter when the cover is on, being sure to brush it for circulation; being sure to turn the pump on for maybe 10minutes just to get fresh water in those pipes daily and sacrifice that little bit of water during those 10 minutes. If I get a windstorm etc. I will skim the top and maybe turn the pump on to use the poolSkim etc.. I am not worried about debris on the bottom since I will get it towards the drain/ filter daily and will simply catch up when I get a new filter.
All comments appreciated
