Hi everyone-
I decided to take a stab at closing the pool on my own and it seems I've run into some trouble finishing the job. If anyone has any advice, I'd greatly appreciate it!
I have in ground pool with spa attached as well as waterfall. So far, I have used a compressor to successfully (I think lol - fingers crossed) blow out and plug off...
- 6 return lines in the spa
- 2 skimmer lines - one deep end, one shallow end
- 2 return lines in pool wall - again one on deep end, one on shallow end
I am having trouble with...
- drain at the bottom of the spa - I shut off all the valves I could find in order to direct the pressure from compressor directly to the spa drain. But I couldn't get any bubbles to blow out of the spa drain in order to air lock. So, I let the compressor blow for a bit and shut the valve. Hoping this created a little air lock, but I really can't tell if the water line budged or not. Seems like blindly crossing my fingers on this one. I could hear some water clunking around when I turned compressor off. When I knock on the spa drain pipe, it doesn't exactly sound hollow as some other lines do. Any ideas or suggestions? I could probably snake some anti freeze in, blow again, and lock off. At least there'd be some AF in there this time. good idea?
- main drain at the bottom of the pool, which is hooked into the deep end skimmer - I read that you can try to shop vac the water level down and then air lock that. But I couldn't get a tight enough seal from the shop vac in the main drain line. Ended up just sloshing around all the water in the skimmer. Deep end is 11 feet, so I doubt my shop vac is strong enough to clear the whole line anyway. My pool guy last year did seal off this line somehow - so I guess it can be done? SHould I just shove in some foam rope and plug it?
- two more lines in the top of the deep end - see the picture attached. They are covered normally so I am assuming they are suction lines. And they didn't react at all to blowing out any of the return/skimmer lines. Does this mean they're probably hooked into the main drain line as well? Since I'm not sure the origin of these lines, I don't have any ideas how to go about blowing them out. Please help. Again, I could probably get some anti freeze in here and plug, but not sure if that's as optimal as blowing out.
Any advice as to how to more confidently blow out these remaining lines? or better ideas for Plan B? :|
Thanks!
Thanks!
