Hello Forum Member:
New homeowner that came into a headache. My wife fell in love with this house that was marketed as having a solar pool system 3 months ago. Our electricity and water bills came and we aren't saving a dime for the 1st and 2nd months. Our first 2 water bills were over $350.00 and our light bill was about the same amount. i started noticing this issue and decided to look around the pool area and noticed we had a running floater fill valve which I replaced (due to low water). Come the 3rd month we saved about half on the water bill due to the fixed floater valve. I then noticed our Hayward pump was really loud and running dry for days and days. After much researching I figured that the pool just needed to be filled with water and slightly passed the calcium line on the wall tiles, but 8 hours later after the filter turned off the pool is drained again but only drains till it reaches the same level as the skimmer basket therefor causing the Hayward pump to run dry. I have played with the valves and refilled the pool over and over and main issue is the water is draining only until it reaches the skimmer and only when the filter motor is off. Can you please help a new pool owner diagnose this issue. I called a few places but they want $75/100 just to come and diagnose. I feel confident in this forum that you can lead me in the right direction on fixing this problem, but just need explanation of the proper valve position and what half this stuff is. I know the major components such as the DE, heater pumps etc but cant really find info on the solar stuff.
Questions I have for you are:
1) What is the correct position the valves need to be in when the filter is on?
2) Is this a complete solar system for the pool? How can I tell if it is in solar mode what is solar on or off valve mean?
3) Can I remove the skimmer circle plates below the basket (basically leave the twos holes open) Unsure if the previous owner had an in water vacuum bot
4) Unsure if the labeling on the pipes are correct...Are they?
5) Does the heater need to be on, because I completely turned it off
6) I turned the red valve to the horizontal position. Is this OK? (No change)
https://imgur.com/a/oEo2cdI <-----------PHOTO ALBUM
Here is what I have done so far by myself:
1) Cleaned the DE Filters and added DE to pool (drained wash out sediment inside etc)
2) Replaced the water fill floater Valve
3) Cleaned out the Salt Cell w/acid
4) Replaced both Check Valves (followed flow arrows)
5) Replaced a noisy waterfall motor (not by me..beige in color)
6) Replaced Hayward Pump Rubber O-Ring (Lid)
After all this servicing done by me There are no water or air leaks. Thank you for your time and hope you can help me
