Hi, I have an inground spa which we use as a pool and do not heat. I have had trouble calculating the size mostly because of the wrap-around bench, which in turn makes adding the correct amount of chemicals tricky. I have attached a photo. Outside dimensions are 122” x 76”. Depth to middle is 48” and depth to wrap-around seat is 24”. I appreciate any help.
