- May 3, 2007
- 16,964
- Plaster
- Hayward Aqua Rite (T-15)
If you assume the following:
Two Speed Pump SP2610X152S
Cost: $300
High Speed Run Time: 1 Turn/day @ 67 GPM, 2.7 gallons/watt-hr
Low Speed Run Time: 1 Turn/day @ 34 GPM, 5.4 gallons/watt-hr
EcoStar Pump
Cost: $900
High Speed Run Time: 1 Turn/day @ 40 GPM, 12.3 gallons/watt-hr
Low Speed Run Time: 1 Turn/day @ 30 GPM, 15.3 gallons/watt-hr
Over 60 months of operation, the EcoStar will save around $1000 in total costs including the difference in price. Even if you assumed that the EcoStar would run at the same flow rate as the two speed both high and low, it would still come out ahead by over $500.
If you do go with the EcoStar, look into the ProLogic instead of the AquaLogic as the later is being phased out.
Cost: $300
EcoStar Pump
Cost: $900
