We just had our pool built last summer, and the color was mottled and somewhat uneven... not severely but I wasn’t thrilled. The builder called the plaster contractor to have them work on the plaster. This week the pool was drained by the plaster company and, as it turns out, the entire pool appears to have been covered by a layer of white haze which really became apparent after draining. (The mottling shown is much more pronounced with the pool drained than it was with water in the pool, to be fair, and the plaster was in the process of drying to some degree.) The plaster contractor acid washed and polished the entire pool using diamond pads. The color looks much darker now and very even, however I am concerned with a couple isolated areas at the bottom of the pool wall where there is some cracking (hairline) and rough/pitted surface texture.
Anything I should do to document this with the plaster contractor case it causes issues down the road, or is it within the normal limits of surface variation per the workmanship standards of the pool industry? I just don't want to have major surface failure issues 5-7 years down the road and have the plaster company blame me for "improper upkeep" or some other nonsense excuse.
The finish is Wet Edge Altima with Tahoe pigment.
