- Apr 22, 2024
- 10
- Plaster
- Hayward Aqua Rite (T-15)
Greetings all,
I am a new pool owner and this is my first time posting in this forum. TFP has been a tremendously useful resource and I thank you all for your efforts in making this site what it is. My pool is about 6 months old, 13,500 gallons, plaster finish, with a Hayward TurboCell T-CELL-15 SWG. My current chemistry levels (as of this morning) are as follows:
FC - 6.4 ppm
CC - 0.0 ppm
pH - 7.6
TA - 80 ppm
CYA - 70 ppm (I think, the test for this chemical is my nemesis; I really think I need to go see an ophthalmologist
CH - 340 ppm
Salt - 3,000 ppm
My question is in regard to persistent white spots in some areas of the plaster finish (see attached image). The person from the pool company that originally set the pool up called it "fat" and he did not seem too worried about it and said they would eventually go away. He suggested keeping the pH in the high 6s or low 7s to help this process. He also mentioned throwing some muriatic acid in the area, letting it settle onto the surface for a few seconds and then brushing it off. I have been hesitant to do this. Today I went in there with a pumice stone but it did absolutely nothing. I have brushed the pool religiously (every day for the first month and at least 3 times per week since; I have the arms to prove it), but these spots remain.
What do you guys think? Should I try the suggestions from the pool guy or are there any other approaches that may be better/preferable?
Thank you for your responses.
Cheers,
Marcos
FC - 6.4 ppm
CC - 0.0 ppm
pH - 7.6
TA - 80 ppm
CH - 340 ppm
Salt - 3,000 ppm
Cheers,
Marcos
