Need some help from the TFP Community.
I got my plaster redone last year and noticed it was just "off". The plaster company ended up agreeing and two months ago they drained my pool, go the moisture out of the plaster and it's looked great. Then all of a sudden I was seeing a bunch of yellow stains around the pool. The plaster guy came back and said metals in the water and to use Natural Chemistry Stain Free and Regal Metal out. The recommendation with this is to have FC at below 1PPM. The rest of my chemistry is/ was
PH 7.5
TA 80
CH 400
CYA 50
After doing this i wasn't noticing any yellow going away, but the water continued to get more algae like in the texas 110 degree heat. I was then told the natural chemistry stain free was essentially calcium so i went on amazon and bought a bucket that i saw folks were using for pool staining. I put in a couple pounds of calcium throughout the pool in the areas where I wanted the staining to go away.
Once again, i didn't see any change other than the water continued getting super algae like and i believe from the calcium powder made it very cloudy in the pool. I did a backwash as that was the reccomendation after as well and recharged my DE filter.
To get rid of the algae ive done a SLAM for 36 hours. The pool water is now clearing up, but what is now showing is a disaster on the plaster. The yellow marks have turned brown like and they are everywhere. At this point i have no idea what to do and have already went through about $100 in chemicals so would rather get some advice before i do anything else.
The Dark blue water photo is the before all my chemicals with the staining i noticed. the lighter blue water photo is right now after i am seeing the aftermath in the sunlight. I have tried seeing if this comes off at all with my hand/ the brush/ etc but it's stained.
PH 7.5
TA 80
CH 400
CYA 50
