Hi everyone! Just de-winterized our pool last week and discovered some cracks in our Wet Edge Primera Stone finish in the spa. The finish is only two years old and is pretty much cracked in every corner of the spa to different degrees. The cracks are big enough that you can catch a fingernail in it. I was suspicious last season that we had a leak or something as we were getting quite a bit of calcium efflorescence in a few spots on the outside of the spa which is all tile (spa is raised 18"). There are no cracks on the tile on the outside of the spa so I'm not thinking this is a structural issue.
Pictures are attached. The spa was drained down so that the jets could be installed - it was not left empty over the winter. The pool was just de-winterized so it's a bit dirty (it's not normally like that!).
Any thoughts?
Any thoughts?
