- Jul 17, 2018
- 127
- Plaster
- CircuPool RJ-45
Hopefully I've posted this in the correct category.
I am planning on adding a gas heater after my electric heat pump and have the return from the gas pump hook up right after the electric heat pump's outflow.
I've drawn out what I think the plumbing should look like. See attached picture of my current heat pump and piping.
Can I get your feedback of my piping schematic? Could there be a better way? Any corrections?
The pink highlighted are the valves I believe I will need and where I will install them. The 2 green highlighted are check valves I think will need as well and where it should be.
Thank you for your help.
