Likely a contributor to my failed pump motor / shaft seal — our impeller gets a lot of pine needles to the point of needing to dismantle the power end off the pump, pull out the needles that are stuck, and then reassemble. Signs I’ve needed to do this included air in the strainer basket, low Flo indicator on the heat pump, or just standard filter maintenance.
We keep a solar cover on 90% of the time and skimmer socks (hair nets) to try to keep the debris going towards the pump strainer to a minimum, however pine needs still make it through.
Given the tree is on my neighbor’s property (I’ll take to them about removal, but it’s easily a ~150’ tree), what recommendations might you have at the pump strainer to contain pine needle and reduce pump wear/tear?
