So since I just got my pool, I was using the pool math calculator (I should have read about the SLAM process) but since my water was new from the hose, I never tested the initial water but I recall having this issue last year with my intex pool. I am waiting on my test kit to arrive, so I decided to take advantage and use the free test at Leslies so I can see where I am at and what I need to do.
So May 8th I added 1 gallon of 10% LC. May 9th I tested water and FC was around 1.1 CYA was only 5 alkalinity was low think it was 20 and PH was 7.2 and Phosphates were 2000
Today May 13th I tested water again, FC is 0.09 and TC is .5 (this is my fault forgot to add more LC got busy with other projects) Since the last time I added 3lbs of CYA and about 3lbs of Alkalinity up. My new test came back: PH 7.8, Alkalinity 65, CYA 15, and Phosphates are now 4000.
I don't have any leaves or trees near by by this stupid little whispy fly from somewhere and still get into the pool. I have emptied the skimmer basket each day and skimmed the pool. Waiting on my pool vac to get here but the bottom looks pretty clear of debris to be honest. My PH being at the top end I didn't want to add any more to up the alkalinity so figured to just focus on CYA and FC at this point and address the Phosphate reading.
I added 3.5 lbs of CYA today (according to pool math) after the test hoping this gets me to 40.
Pool math said to add 58oz of 10% LC to get to 3 ppm. however last time I add 1 gallon this same LC it only got my FC to 1.1. So I added 1 gallon of the same 10% LC again tonight. I suspect the 4000 ppb phosphate reading is eating up all the chlorine and I probably will need to added even more LC tomorrow.
So what do I do about this phosphate reading? I do have that nophos stuff that leslies sells from last year where I had this problem with my intex pool. I remember when I used it after 24 hours it gunked up my cartridge filter but good. It worked though but I figured I should ask here first and see what I should do before proceeding any further. Any help is appreciated.
