I see your point with the pucks, but for a SWCG user who keeps CYA at 80ppm, I personally wouldn't want to add any more. Yes, I could do a partial drain and refill to lower CYA, but then I'd also have to add salt and borates (and maybe have to adjust TA) to bring those levels back up....and of course there's a cost associated with that.
I too in this case wouldn't want to add more CYA either here. The thing is however, you've still got your SWG to provide chlorine while you're away. It would only be some malfunction that would cause an issue, be it power failure or equipment breakdown. In these cases you're likely to face some issues anyways as you are now in a scenario that requires manual labor to help out. As another option you could take to save some cash would be to simply manually add chlorine to your SLAM of 31ppm level and let it go from there. Assuming you drop 3ppm FC per day at the end of a week you'll be looking right around 8-10ppm FC......still well within the 6-11 FC goal you would aim for on a normal basis. This is assuming the malfunction occurs on day one too.
Excellent posts, Joyful.![]()
I couldn't agree more with this comment! Great job Matt helping us ALL learn alot more about this subject!!
