As I said in the linked post, the actual unit tests 3 things, pH, ORP, and temperature. ORP sensors are used to measure chlorine but CYA throws off the results, so you are left with a wifi pH and temperature sensor. So how do they measure everything else? Test strips...
Yes, very interesting concept, I would buy a dozen of them if they measured everything the TF-100 measures and did it accurately. But as usual in the pool world, marketing sells you on filet mignon and a box of ground horse meat arrives instead.
