pH won’t stay down
What is your TA and are you inputting your current TA in the Now column of PoolMath when you get the acid amount to lower your pH?
Take care.
Just keep adding acid when it exceeds 7.8 and you may find that as your TA get closer to 50-60 then it may stabilize.
Ill keep adding. Thanks. I’m not going to worry about TA being lower than the pool calculator suggests.
TA is 80. Pool math is how I knew how much MA to add to get it down to 7.2 but it didn’t stay there.
