New kit received. Still have been running the setup the same way for aeration. Only ran the soaker hose / compressor for about 4 hours yesterday. I did add 12 pounds of baking soda back into the system following the unchanged pH and new low alkalinity readings on Tuesday morning.
Current levels
PH 7.6
Alkalinity 140-150
FC 5.5
CC less than 0.5 (just a slight off from clear, wouldn’t even call pink but could tell something was changed)
CYA 40 (bumped from 30 as I will be seeing rain supposedly for next 5 days starting this afternoon / high temps / the crappy air right now, and if not a lot of rain I will be adding 3-4” of water from tap)
Calcium 75
Will be cleaning filter today or early morning following a vac (little debris on bottom, nothing concerning. Filter pressure has not changed from starting pressure more than 1-2 PSI). Water still pretty cloudy but improved some from the white water mold. I can see the deep end drain again.
Should I add a small amount of acid to bring all where I want now, 90-100?
