18k gal. chlorine plaster pool. Taylor liquid test kit. Replastered about 60 days ago. TA is at 70, trending down from 80 over the last two months. I expect TA to go below 70 soon.
Subject is pretty much it. Pool stays at 7.9. I can get it down to 7.8 on occasion and it'll go over 8.0 if I go a few days without adding acid.
Every morning when I test I add acid to get back to 7.6. I'm about to go add acid this morning and I'm sure if I test again this afternoon after adding acid it'll be back at 7.8-7.9. I was testing about four hours after adding acid for a few days and same result--7.9-ish when I test, add acid to get to 7.6, four hours later...7.9. I'd worry that I'm colorblind except I had one test, once, at 7.6...week ago. I'm looking at the tube in sunlight at a white (or off-white) background. I'm starting to think I'm just testing wrong. For a while I thought I was just insane and if I did nothing it'd stay at 7.9, but no, it will creep up past 8.0 if I don't keep acidulating it.
Reagents are not expired, acid is new.
I don't want to damage the plaster, and the pool is fine to swim in. Is there a drawback to just letting it stay at 7.8-7.9, or do I need to keep plugging this thing with acid every morning? I'm starting to worry that all I'm doing is leaching the plaster and I should just let it ride until next year and it's completely cured.
