Great thread, and while I don't have much to add beside my own personal obvservations, they may be applicable (or may not, you decide).
I have a newly redone pebble pool, opened in late April. After that first month, running the pump on 1500 RPM 24x7, I turned on the SWG and got my FC to around 5 after some tinkering with the SWG percentage, which was around 20%. 25 seemed to make it climb, 15 seemed to keep it steady around 3 or 4, so 20% seemed right. But with a pool cover on most of the time, except when swimming, with CYA of 60 my FC loss was almost nothing. The PH would rise rise constantly, about .1 per day. Every 4 days I'd throw a gallon of MA in there, drop the PH by .4 (usually from 7.8 to 7.4) and the TA would also fluctuate between 80-90 with each PH rise and MA dose. I went away for 10 days and despite having a "pool guy" check it and add MA for me in the middle, I returned to 8.1, so two gallons of MA go in, down to 7.2, and the rise begins again. I just assumed my PH rise was because it was a new pebble finish and I did wonder if it would stop eventually. Then I read some threads on TFP showing its a normal side effect of having a SWG. Oh ok, I stocked up on MA to deal with what I thought was just my pools normal acid demand. Also, with the cover, and thus almost no evaporation, I'm barely replacing any fill water at all. My water bill confirms this, undetectable difference to prior to filling the pool. Autofil dribbles just a trickle, occasionally, usually after a swim but its a tiny amount.
But then I started considering solar electric, and that means changing electric plans to "Time of Use" and 4PM to 9PM is peak time. So to prepare I stopped running the pump 24x7 @ 1500 and 20% SWG, and started running it 18 hours 15.5 hours per day at 1650 RPM and 30% SWG. Well my FC shot up to 10, so that was too high on the SWG. But I also noticed that at the same time, my PH rise basically went to zero. I added one gallon of MA the day I made the change to drop from PH 7.8 to 7.4, and its at 7.5 since then for well over a week, including running a fountain for the past two days to cool the pool down. I lowered the SWG to 5% to let my FC drop back down to 5, and it dropped to 3 so I went back to 10% and we'll see where that gets me. My point of all this is that changing the time and the % on my SWG is the only real big change I made and my PH rise has basically stopped.
My hypothosis after reading this thread is this. Water running through an SWG at various speeds should produce various levels of bubbles. Like with propellers on boats, there should be a theoretical number where there is the least cavitation, the most efficient passing of the water through the SWG, which creates the least amount of bubbles. This -may- explain why some people, even in this thread, experience different results simply by turning on their SWG, and others experience no change. Perhaps adjusting the run time and pump speed and % output of the SWG, one could find an ideal setting where the bubbles produced do not contribute to any PH rise and the rest of the chemisty takes over?
Or maybe I'm entirely full of baloney in which case feel free to tell me so
All I know is, I tinkered with my run time, pump speed and % and my PH rise instantly stopped. Now what do I do with all this extra MA I have on hand?
